1977 Johnson V4 85hp runs perfect then suddenly loses power, will run full throttle for about 40 seconds and then lose power, if i pull the idle up in time i can save it and bring it back up to full throttle again but the same will happen again
also it sometimes runs great at idle other times it wont idle at all
I assume the carbs are properly adjusted because when it runs it runs sweet, i can only assume its the fuel line or pump? any help would be great.
