kfa4303
Banned
- Joined
- Sep 17, 2010
- 6,094
Re: Got my first project boat. looking for ideas and recommendations.
+1. I've also read several posts/threads from members who have had good success using Gluvit to seal his wooden components recently. It's also and epoxy product that you can/should apply to the interior, riveted seams of the boat to prevent any possible leaks. It should also be a bit more readily available at places like Lowes/HD, than other 2-part epoxies like West System. In fact, you can virtually everything to do your whole project at any Lowes/HD except the f'glass and/or epoxy supplies, unless of course you can get Gluvit there.
+1 on the NON-Pressure Treated lumber too. The preservatives will have an electrolytic reaction with your aluminum hull which will lead to pitting. Be sure you use aluminum replacement rivets and/or stainless steel hardware (preferably dipped in 3M 5200 marine sealant) throughout too.
As far as lay out goes, that boat is screaming center console, flats boat to me, but I'm down in FL where we have lots of ankle deep water, and I'm not sure if that's what would work best for MN. Either way, be sure you also add floatation below decks for increased buoyancy as well. Pool noodles and/or pink(or blue) closed-cell, insulation foam boards sold at Lowes/HD work great and will never get waterlogged.
That's really about it; Non-PT wood sealed in any of the methods mentioned, aluminum rivets and Stainless Steel hardware, the rest is only limited by time, money and imagination. Per the previous post, Tinboats.net is also a great site to see other aluminum boat projects. Good luck. Keep us posted. We love pics
