SleekWolf
- Joined
- Jun 3, 2011
- 48
Re: 1977 merc 1150 water pump question
Nope, the pee tube is still hooked up. I have a feeling a spider built it's home in there and has gunked it up.
I'll check it out more tomorrow. As for water coming out the square hole... there are 2 of them side by side on the back, behind the pee tube. Do you know what these are? if they are exhaust ports or something, water coming out of one doesn't sound good.
I checked out the linkage (and yes everything was previously lubed) and it is barely moving the butterflies. And when I go that "extra inch" of travel the lever is way down in front of the tach connector. Well I need longer cables anyway... so until I get them I'll disconnect the cable and rev it at the motor to see if that's the problem.
Now your carb problem... if gas is spitting out that jet, the needle is not seating properly and allowing fuel to continue pumping into the carb. One of mine looked fine, but still wasn't seating. After the rebuild it seated and worked perfectly. It could also be that the float is not floating and pushing the needle closed. Definitely do the rebuild, and while the cover is off pour some fuel in the bowl and make sure the float if floating. I've read the alcohol in fuel now can detgrade the floats. If you can, stay away from gas with alcohol. If I had the money I would have just replaced my floats, but I'm on a tight budget and don't want to dump more into this until I'm sure it's going to run right
Yeah I asked about the water... none comes out of mine there until the motor is running.
Ah isn't boating fun? Wait... I haven't had it out yet, so I wouldn't know! lol
