eggs712
- Joined
- May 8, 2012
- 402
I have a '77 Mercury 1500, and I have no spark on any cylinder. I used the CDI ignition troubleshooting guide, and I think I may have narrowed down the problem... I removed the mercury tilt switch, I have 12V getting to both the red and white wires on the starboard side of the switch box, and I have 12 volts to the brown trigger wire. However, I get no power at all from the green coil wire that goes from the switch box to the ignition coil at cranking, which should read very high voltage were it properly working.
Does this indicate a bad switch box? Or could something else cause this? Lastly, if my switch box is bad, can I fix it or make a new one myself? Thanks for any help in advance.
