1977 Mercury 850 Question
Shadow662
My question is when the throttle is in the neutral position the propeller still spins slowly and the reverse isn't working. When she is put into forward gear the propeller spins like normal. Anyone know what could be wrong that the propeller spins in neutral and don't have reverse?
She worked fine last year until the water impeller went out. So we replaced that this year. We put it all back together and now this. I'm not sure if the 2 can be related or if something could have happened after we put in the new impeller.
rabeck5792
Re: 1977 Mercury 850 Question
sounds like shift in misindexed.when you install gearcase,it should be in forward & so should the control box.
Shadow662
I didn't install the impeller my brother in law did.
Is that something that can be caused when replacing the impeller? Any idea how to fix it?
Thanks
sportsmanphil
Remove the lower unit, put the throttle in forward, reinstall the lower unit.
