1977 Mercury 850 Questions
tallcanadian
I am looking for a lower unit for my 850.It's not that this one has any major issues but I noticed when I bought it that there was a bit of a grind in reverse, like it wasn't going all the way into reverse. I was thinking that the easy way is to pick up another lower unit and throw it on. My question is what lower units will fit this 850? I was told that the 3 cyl Merc in that year area will fit but looking at my '76 it doesn't look the same. Are there any other year, hp lower units that will fit?
Faztbullet
Re: 1977 Mercury 850 Questions
Any of the 4 cylinder engines 650/75/80/85/850 hp will work as they are 2:3:1 ratio..
Chris1956
Honorary Supreme Mariner
Gearcases from IL6 motors can be used as well. The gear ratio is normally 2::1 on these, so a prop change will likely be in order.
If you shift slowly AKA ---" granny shifting " they will grind going into reverse.----Outboards MUST be shifted with a firm and quick motion.---Easing it into gear is a mistake !
Faztbullet
I disagree as it kills the bottom end grunt unless its on a small lite hull, been there and tried it.
tallcanadian
Great info from everyone. I wasn't '' granny shifting, trust me.'' It just seemed to grind a bit. Now I only ran it a few minutes when I bought and it has been sitting since. I will know more in the spring. I appreciate everyone's input.
