1977 mercury outboard inline 6 ran good now wont start maybe fuel problem
jokers0204
i have a 1977 mercury 1500. i took it out and drove it for about 10 mins and it ran like a top:D then it just killed and wouldnt restart for anything:mad:..... the fuel filter was milky white and the bottom carb was dripping this milky white stuff into the cowling:eek:.... havent tried anything with the motor fuel pump or carbs because im a noob any suggestions what the problem might be or how to get her running again:confused:????
redjmp
Re: 1977 mercury outboard inline 6 ran good now wont start maybe fuel problem
Sounds like water in your fuel.
Are you adding clean oil to fresh clean fuel at the correct rate??
Or are you using old fuel?
Portable gas tank or built into the boat?
jokers0204
fuel was old.... shuda drained it but thought sea foam would take care of it.... oops... if id did suck water through the fuel into the engine would that make it die and then not start again??? if so then what do you suggest i do to fix the problem.... is it really simple or should i just take it to the shop and have them take a look at it.... i just got married and bought a house so i kinda cringe at the $80 per hour to work on it and if its something i can do myself then i would love to save the $$$$$$$$
jokers0204
18 gal aluminum tank in the boat
