1977 sea ray not starting
77searay197
I have a 1977 sea ray 197 bow rider I bought not long ago as my first boat. It has a mercruiser 233 in it. I went to take it to the lake this past weekend and turned te key and nothing happend. None of the switches worked or anything. I started it the night before and madr aure everything was working properly and everytiing was. I know I'm gettin power to the solenoid but the problem is somewhere between the solenoid and the ignition switch. Is there a place where all the wires meet and go into one big wire? Since it's a old boat it doesn't have a fuse panel like the newer boats have. Thanks for the help
81 Checkmate
Re: 1977 sea ray not starting
Get your multi meter out and start chasing the wires down.. Both ends/grounds also
If no fuse panel it has to have some in-line fuses.
BTW...Welcome to iboats
77searay197
Ok thanks guys I appreciate it. I'm sure there's alot of good info on this site. I'm going to look at it this evening and tomorrow and see if I can get it figured out
