1977 seaswirl omc 190 issues
runabout1321
Greetings all,
I recently purchased a 1977 Seaswirl with an OMC 190 I/O motor. when I purchased it I had charged the battery and used some starter fluid and the motor fired right up. I took it out to the lake and cruised around for about 3 hours constantly turning off the motor and firing it back up. one particular time I cut the motor and it did not turn over. I took it home and since then have -replaced spark plugs
-ensured i had good fuel
-cleaned distributor cap
-installed new ignition wires
when I try to fire up the boat it just cranks but does not want to turn over. any thoughts on the issue?
dubs283
crank = turn over
thinking you mean, engine turns over but does not start/run
since you've investigated fuel, next check would be for good, strong spark at the coil
Did you do any maintenance? Any new to you used boat needs all the maintenance done
Service your points, use a dwell meter to set them. Set the timing
Service the fuel system
Pull the drive and inspect the ball gears. Split the case and change the raw water pump
kenny nunez
2X s with Scott on the ignition. You might want to look into a Petronics ignition conversion. OMC used Mallory and Petronic brand distributors.
If there are no overheating issues at this time you may get by on replacing the pump in the drive for now.
How much material is left on the ball gears right now?
