1978 115 hp merc o/b speedometer cable
JZEVINRUDE
Is the cable from the boat console to the engine lower unit a 2 piece cable? It looks like it might be , but how do they come apart so I can remove the motor from the transom?
Thank You
JZEVINRUDE
Re: 1978 115 hp merc o/b speedometer cable
Gerry you are correct, they do just pull from each other. a little heat from a lighter loosen up the insulation. thank you
