1978 115 hp mercury
frbal1960
my mercury wont run full throttle it sounds like its missing when i go to full throttle but when i remove the sparkplugs and leave them out for a few minutes it will run full throttle till i back the throttle down to run slower then it wont go back to full throttle does any one know what could be the problem?
Yepblaze
Re: 1978 115 hp mercury
Are the spark plugs soaking wet with gas?
Is one of the carbs leaking gas?
Do you think it's maybe flooding out on a couple cylinders then running ok after you dry out a couple cylinders?
frbal1960
i was told by some friends that the motor may be carboned up and that would cause it to buck at full throttle
Yepblaze
You could work over the carbs. Clean the dist cap, or check the plug wires.
Chris1956
Honorary Supreme Mariner
That is atricky problem. It sounds like one plug is fouling.
What do the plugs look like? Are they wet with gas, it could be a bad fuel pump diaghram letting raw gas into the crankcase. If they are dry, it could be a weak fuel pump. If the plugs are very clean, it could be water infiltration steamcleaning the plugs...
frbal1960
the plugs are dry and i just rebuilt the fuel pump thinking that was the problem but i was wrong i guess
daveswaves
Ensign
What do you mean by sounds like it is missing? Is it knocking or pinging on acceleration? What RPM is full throttle? Are you able to reach 5000 rpm or does it die out before you get there? Does it ever run smooth at full throttle?
There are filters in the top of the carbs that can plug and restrict fuel flow at high speed, causing a lean condition. You have to remove the fuel lines to get at them. They should be removed completely. Check your fuel pressure, should be at least 4 psi to provide enough fuel flow at WOT for that engine.
frbal1960
yes it runs great at full throttle nice and smooth till i back off the throttle the it will start bucking when i try to go to full throttle I will try the filters then let you know what happens thank you and also i can get to about 10 mph on the speedometer i dont have a tach on the boat
daveswaves
Ensign
Unless you have an extremely big boat 10mph is not indicative of full throttle. There are lots of things that could be happening here. Your prop hub could be spun which would give you high rpm and no speed.
