It will go up, but it wont go down
Worked fine three months ago. Was stored in vertical position.
Went to start the engine today. Tilted it up and it would not go down.
Could not get the release screw to open so disconnected the hydraulic line on bottom of unit to allow fluid to drain and motor slowly came back to vertical position.
Refilled reservior, tried again, it will go up but not go down.
Motor is running in both directions, can hear motor strain in trying to get unit to go down but it only moves about a half inch then stops.
Manual says trim check valve plugged: pump control piston failing to open check valve or several other parts.
Any suggestions on what I should check first, order of sequence?
