1978 1150 Hose Going To Top Of Head
jeast
My 1150 has a rubber hose ,going from the top of the head to the bottom on the wiring harness side.. it seems when i pump to much gas and it doesnt start gas appears to leak from the top of it. anyone no what this is? thanks
AMD Rules
Re: 1978 1150 Hose Going To Top Of Head
Sounds like the bleed line, to lubricate the upper bearing. If its leaking, fix it. If not, you'll be replacing that bearing soon and then some.
