spitfireap
- Joined
- Oct 22, 2016
- 21
I just replaced the corroded wiring harness on my 1978 1150 "Tower of Power". I was careful to take photographs and label the old harness before removing it. Unfortunately, it was so corroded that many wires fell apart as I removed them which is making installation of the new harness more difficult. I need help with the wiring of the red wires on the new harness. According to a wiring diagram I found for this motor, the red 18 gauge cable goes to the 2nd post up on the switchbox and it also connects the rectifier to the switchbox via jumper (ignore the arrows in the pic).
The photo of the rectifier I took before disassembly has a jumper coming from a different post of the rectifier (one with a cable from the stator). (Also, what's the dark red cable attached to the rectifier labeled "G" at the harness in the diagram above? That color is not included in the index at the bottom right of the pic. I have 2 extra cables from the harness that I don't have connected to anything (orange and brown). I know brown is for the tachometer (which was disconnected on my boat) but what's the orange for?
What's the right answer? These 2 seem to disagree. Finally, here's a pic of the setup of the new harness so far. What's the right way to wire the red cables? What do I do with the orange cable (right now I have it taped off since the instructions say to do that if not used).
Any info would be great. Thank you.
