1978 1400 battery not charging
fazzollini
I checked all the wiring. I have 14.2 volts at the engine connecter, bridge, ignition box, starter soleniod. I have good continuity to the battery, but only 12.6 volts at the battery. Any ideas.
Dunaruna
Re: 1978 1400 battery not charging
Hi patchit, welcome to iboats!!<br /><br />Remove the batt terminals (both) and wire brush them, then test again.<br /><br />Aldo
fazzollini
I have done all that. I think I might try changing out the battery.
briannh1234
Most auto parts stores will check a battery for free. Pull the battery and let them test it.
Clams Canino
If you have 14.2 volts at the starter solenoid. How can you not have it at the battery? Same source.<br /><br />You using a different guage for the 2 tests.<br /><br />-W
