Star64!
Thread starter- Joined
- Mar 12, 2021
- 6
Pulled floor out of leaky Starcraft and found a couple of leaks when couple of inches of water were in bottom of boat. Was told to float boat to get better idea of issues. When in water I could see huge problem. All rivets down center of boat were letting in water. Back side of rivet dissolved or corroded and all that was left manufactured head on bottom of boat and shaft in hole. Slight tap with punch from inside and rivet dropped out. They are 3/16 rivets. Hole is in perfect shape no signs of corrosion.
Is this normal for 44 year old Starcraft? Rivets thru keel, floor and rib are still ok. Only 2 rivets between every rib has failed. Could they have installed them poorly at factory or used wrong rivet?
