1978 175hp Evinrude Rebuild - Starting Up
Breilly
I have just finished rebuilding my 1978 175hp Crossflow Evinrude. I powered it up once but it took quite a few cranks to get it running with a flush kit. It idled fine in the drive way. Unfotunately I had to take the carbs off to adjust the shift rod.
I have since put the carbs back on and was attempting to restart the engine in the driveway, it was still taking a long time to start after a while it sounded like it was going to kick over and it even did a few times, however I had cranked it so many times I wore one of the brushes out on my starter motor. I am now waiting for the starter motor brushes to come in.
I am wondering if there are any tricks to getting it to run properly. I have brand new plugs in it that i will probably clean again before trying to restart. Not sure what else to do and if this is a common problem after rebuilding?
Thanks,
Breilly
jonesg
Re: 1978 175hp Evinrude Rebuild - Starting Up
Do a spark test,
try spraying premix fuel directly in the carb throats.
One of those two tests should show the problem,
if it still will not fire up consider a problem with the reeds.
This assumes you have good compression now.
emdsapmgr
I take it that the choke solenoid is fully closing the choke plates. As you are trying to start it, are the spark plugs wet or dry?
James R
Absolutely check that the choke sol is closing the butterflies fully. The motor wont fire if they are not fully closed.
