chuckp
Thread starter- Joined
- May 21, 2011
- 19
Hello Guys,
I purchased a 1978 35 HP long shaft tiller steer manual start Evinrude (model no. 35853R) a few weeks ago - first time I ran it I noticed how hot the water output was. The tell tale had a good output and the exhaust housing outlet had good water output at throttle while underway although some of the water steamed and was too hot to the touch.
I put a water pump kit in it and replaced the thermostat and water jacket gasket (old stat was plugged up and non-functional) after cleaning surface crude (it was not too heavy) out of the water jacket passages. Water coming out of the tell tale is still strong and not too hot while the exhaust water flows well underway but is still too hot to the touch. It does not seem to be steaming as much but still goes up to 160 deg at the top of the crankcase with a infrared temp gauge.
So is 160 deg too hot for the motor? The paint shows discoloration on the top, left hand side of the crankcase and head as pictured below. Should I pull the head and check the passages and water deflectors next or check behind the exhaust covers? I have an OEM manual on order - does anyone know what the torque should be on the head and exhaust cover bolts?
Thanks!
Chuck
Thanks!
Chuck
