1978 35 HP not starting
Fullspectrum
Pulled the boat out to fix for the season and was able to get her to fire up at first.
A few hours passed and I went back to fire it up and it just suddenly stopped and will not start. At first I thought it was the battery so I recharged it and nothing. I replace with a new battery and new ignition switch and still it will not start.
What do you think may be wrong. I was able to get it to go and within a day...it just stopped. No spark...nothing what so ever. Turn the key over in the ignition switch and nothing happens...not even a click. Help!
david_r
Re: 1978 35 HP not starting
the key dont work...check the fuse by the solenoid it looks like a regular wire connector but is has a fuse inside.
if its spark you dont have i would unplug the main wire plug and jump the solenoid and see if you have spark then....if you do you have wired the sw wrong, you may have a bad neutral safety sw, or you have a bad wire.....the black w/yellow stripe goes on the raised "m" on the se by the way.
tx1961whaler
Go to the top of this forum and click on the "TOP SECRET" Thread, then the "Won't start" post.
