1978 35HP Johnson overheating after stator replaced? 35EL78R
DevinM
A few weeks ago I was on the creek and lost spark. It was obvious that the stator went bad after i pulled the flywheel. I have a parts engine (that I overheated already and scored the cylinder walls) and decided I would replace the entire electrical system including rectifier, power pack, armature plate, terminals block, flywheel etc.at once. The stator that went bad was 'normal' looking to me with metal plates stacked on top of each other and the one I got off the parts engine was green and maybe was the same thing but filled with like resin to keep it all sealed? Anyways after the swap I got spark and the engine to start and idle with the muffs.
I then launched the boat and it couldn't get on a plane. I figured I would check timing as the manual says it would need to be checked if electrical components are replaced. Once I convinced my sister to come aboard and give it WOT I found out that I wasn't getting spark on cylinder #1 (timing light wasn't strobing once throttle advanced). I immediately swapped power pack and coils and we were up and running in no time. I thought all was good until I checked tell tale pee hole and it was hot. The exhaust holes were incredibly hot and the head was so hot I couldnt leave my finger on it for anytime at all. I know this engine shouldnt be near as hot as it was. I wish I checked timing after I swapped PP's while I had a deck hand but I didn't think to at the time. The book says CDII ignition systems don't have adjustable timing but there is a screw to mess with to advance/retard and a spec on the air box for advanced throttle. No spec for idle timing I can find.
I have many many hours on this beauty and it has never been that hot. I then checked water pump (A okay), removed thermostat (removed that out of the equation) and changed the L.U. oil just because.
Outboard is still overheating and I cant help but notice a lot of black varnish/exhaust smoke? is gathering around where the L.U. mates to mid section. Even more black varnish around were the cover is that you have to take off to get to gear linkage. That must be related to the overheating I am thinking.
I dont know why #1 wasnt getting fire after the working magneto was installed. Then it was getting fire after PP and coils swapped but now getting hot.
Do you think it is preignition because im thinking thats about the last thing that'll overheat an outboard.
I know i need a new head gasket after removing the thermostat but before throwing money at it I wanted to talk to like-minded individuals about the overheating
I searched all throughout the forum for something like this but I could not find anything. I hope I was clear enough and I appreciate anyone viewing this!
DevinM
[No message]
flyingscott
The first stator is a non electric start stator. The green one is for an electric start because it has the charging coils. What was rubbing on that first one to teat it apart like that? Maybe not installed correctly. Look at the thermostat
DevinM
Oh thanks for clearing that up for me. Thats a good question. I dont see any crazy markings under the flywheel where it may have hit. That non electric stator I have been electric starting for well over 18 months now. Also, I may have done this damage when charging the battery while it was still hooked up to outboard? I believe I read on the forum that is bad. Am not doing that now a days. Specially if I have charging coils now.
Honorary Supreme Mariner
Are we 100% sure that the damaged stator shown here is for a NON ELECTRIC START ????
DevinM
Charging the battery while connected to the motor will not hurt anything.
Okay and I have removed thermostat and outboard still overheats. Have not checked operation on stat but it didn’t look too awful at all. But the engine still is overheating when I took it out without the thermostat in. It just baffles me how my stator went out and no I’m chasing my tail around with this overheating issue.
DevinM
everything looked to be installed correctly to me
flyingscott
Leave the thermostat cover off and start the motor on muffs. See if you have a good waterflow.
Are you guys 100% sure that the stator (0763770 ) that was damaged is for ---NON ELECTRIC START MODELS ????----Parts book seems to show it for electric start.----Factory part and CDI aftermarket look very similar.
flyingscott
Nope , In the first set of pics all you see is the driver coil and the pick up!!!!!! Post #9 clearly shows the whole unit.
flyingscott
But are YOU 100% sure the stator is causing the overheat. I will leave the op in your hands since he seems to think the stator is the problem!
I am saying this damaged stator is for electric start !!----I am not saying anything about what is causing this motor to overheat !
DevinM
I am not sure if the stator is causing the over heating. I just know that was the faulty part causing the breakdown and after it was replaced it is running wicked hot and leaving black exhaust looking varnish. Seems so harmful to run it now.
DevinM
[No message]
DevinM
[No message]
