1978 35hp Johnson Woes
larry35hp7
Hi all- I have a 1978 Johnson motor that is a pull start, and would like to convert to electric start. The dealer wants 500 bucks for the kit. I bought a starter and solenoid and bracket off E-Bay for 85 bucks, and a key switch from the dealer for $21. The switch has 6 tabs on it. The dealer would not give me a wiring diagram, and said it wouldn't work.:confused: Something about a neutral saftey switch? Where do the wires go? Any help will be greatly appreciated. Thanks-Larry
tx1961whaler
Re: 1978 35hp Johnson Woes
Of course it will work. A neutral safety switch is highly advisable, but not necessary. Without it, you can start the motor full throttle in gear, which can be a major bummer to your passengers. That's probably why the dealer wouldn't help you. Liability and lawyers and such. Or he was just a jerk. Take yer pick. :D
Read this:
http://continuouswave.com/whaler/reference/ignitionSwitch.html
It pretty well has everything in it you need.
