1978 5.7l pre-alpha with alpha gen 1 drive over heating
Searay205
I love the empty miller lite can in the bilge. At lease somebody had a good time.
Rick Stephens
Once you disassemble your motor it is too late to "pressure test your heads". That is crap. Always do cooling system pressure test before teardown. Screwing yourself on ever knowing for sure if there are any cracks until you get it back together.
After cooling system pressure test do a leak down which tells you where your issues are.
Between the two you can target your repairs. Otherwise all is a guess until fully assembled again.
Lou C
Chevy small blocks are easy to take apart & repair but you have to know what you’re starting with. Might want to line up a machine shop to check out the heads if you do wind up taking it apart based on testing
matt0107
I just figured either way it’s getting water in the pistons 4 and 6. From the washed plugs. It’s also gurgling when I shut it down so I’m assuming it’s pushing Water into those cylinders. And the exhaust starts getting steamy after it warms up. By pressure I meant pressure the coolant journals on the heads and check for leaks with water around the valves. They plug all the water passages in a jig. They have the tools to do that. That’s how they check for cracks anyway. Might even have the valves done. Worst case I have a spare set of heads. Or multiple sets. Lol. I just figured either way this thing is coming apart. Does that seam logical?
Rick Stephens
Suit yourself, it's your motor and your money. You won't know whether the block has a crack until you reassemble.
matt0107
I appreciate your input. But if it is a blown head gasket and I pressurize the coolant system. Wouldn’t I not it leak just the same as a cracked head? Always open to ideas anyhow. Just want to know the logic.
nola mike
Not necessarily, and that's what a leak down test would show. Combustion gases are under a lot higher pressure than what you'll be pressurizing the block to.
matt0107
Ok I will grab the gauges. Guess the higher compression could lift the head and push the gasses through gasket to the coolant passage. Where a cracked head would leak easier and even easier when it warms up. Wish I could save time. Just want to get this thing in the water. Thanks for all the replies.
matt0107
Ok I got ya. Wasn’t thinking about cracked block. Just worried about the heads. Thanks.
Scott06
A blown head gasket between those two low cylinders i would expect air pressure to come into combustion chamber and out sparkplug holes if you back the rockers to close the valves.
cracked block that pressure will end up in crank case.
if over head you could also have cracked heads not just gasket
matt0107
Yeah since I don’t have milky oil I’m leaning more against cracked head/ blown head gasket.
