1978 50hp merc impeller replacement
flippa
can anyone plese tell me how to disconect the gear selecter OR DO I HAVE TO ? I HAVE GOT THE HOUSING UNBOLTED BUT CAN ONLY GET IT TO COME DOWN ABOUT AN INCH AND A HALF. WOT AM I MISSING
triumphrick
Re: 1978 50hp merc impeller replacement
I have had a few of those apart and they were splined...but did not come apart easily. Used a wood wedge on the foot to help get it started...
lindy46
Hmmm - if the L/U drops down a whole 1.5 inches, I can't imagine what else could be holding it. At that point the driveshaft should be loose from the crank and it should just fall off. If the shaft were rusted into the crank, it wouldn't drop that far. With that big a gap, you should be able to see inside - check the water tube and see if that is free, and check the shift rod. Are all the bolts/nuts that hold the L/U on fully removed?
crem1
It's a little thing but did you put the gear in forward?
flippa
Thanx Guys. All Nuts On Leg Removed. No I Had It In Neutral.had A Thought Though,should The Exhaust Tube Stay Behind Or Come Out With It?
crem1
It usually stays behind but no big deal if it goes the other way, just re-hook it.
It's the little things that kill you...:)
crem1
It's possible, but I can't think of anything that it would snag on. Not engaging the forward gear is most likely the culprit
flippa
thanks alot. i will be home in two days i will give it another go.
