natecollins1
- Joined
- Jun 30, 2006
- 37
Hi,
I have a 1977 Evinrude 70 hp. I recently rebuilt the carbs, flushed fuel line + tank, performed sync and Link, replaced spark plugs, replaced water pump and lower unit oil. The motor runs fine at idle, high speed and in forward/reverse on flush attachment. The motor runs fine in idle in the water. The motor stalls when put in gear in the water. The compression in the third cylinder is low (65 psi). The lower unit does not appear to be in any kind of a bind. Do you have any further suggestions for resolving this problem.
Thanks,
Nate
Thanks,
Nate
