1978 70 HP Merc - Can't get motor to tilt up - What am I missing?
RemH
No power trim - manual - seems locked in the down position ?
Any help would appreciated - in the final stages of a rebuild!
dlplost
Re: 1978 70 HP Merc - Can't get motor to tilt up - What am I missing?
Reverse lock probly out of adjustment.
Put shifter into foreward gear, that should unlock it.
Chris1956
That motor should be locked down in neutral and reverse. it should tilt up in forward only.
RemH
Hey thanks for the feedback - boat got in the water yesterday - got it to tilt - a few adjustments still to be made on the carb and replace the fuel line
THANKS
tntwill
man you guys rock i did not understand why mine did the same thing............. thank you thank you
