seedlings
Thread starter- Joined
- Jun 5, 2009
- 92
First run out of 20 year storage. I did not rebuild the carbs because it ran great in the driveway <sigh>, and was run about once a year for 10 years, then put in storage.
In the driveway in neutral or with the prop engaged the motor runs fine, and also runs fine in the water in neutral.
In the water, in gear, the boat dies at 2000rpm on a gradual throttle up. A quick throttle past 2000 rpm and it will run full throttle, or throttle down to any rpm except 2000~2500 rpm.
So this problem only happens under load. Can a prop cause this? See the prop here:
http://forums.iboats.com/showpost.php?p=2154721&postcount=7
Full throttle is a shade over 4500rpm and 30mph.
CHAD
CHAD
