1978 70hp evinrude
tjizzle
Last time had boat out motor would struggle to get up to speed had to baby it when i got boat back in checked plugs middle plug hole seemed to have a little water/gas mixture coming out checked compression all 3 cyl are between 90-95psi anyone have any ideas where to go from here. Any advice is appreciated.
THANK YOU
ONERCBOATER
Re: 1978 70hp evinrude
your pressures are low... now real low but I would be happier with 100-120... water/gas/oil mix on plug almost for sure head gasket leak.... or cracked block... I am voting for head gasket leak as it is middle hole and that sort of precludes water intrusion from lower crank seal.
see what the others say before tearing into it.
Sean
