1978 Evinrude 115 Compression numbers = rebuild?
interalian
On the low side but gauges can vary - try with another gauge? The 20 pound difference between highest and lowest is a concern - is that 90 reading on the lowest cylinder?
Oh, and is this a new-to-you motor or one you've had for years?
Honorary Supreme Mariner
Remove bypass cover on the bad cylinder.---Inspect pistons / rings.----If you keep running it you may do big $$$ damage.
coin operated
It is new to me. I actually haven't purchased it yet.The low reading is on the starboard lower cylinder.
boobie
You can also do a good de-carb on it. You may get a surprise.
