daniel.murphy
Thread starter- Joined
- Dec 8, 2008
- 6
I have not seen or heard of a problem like this before. I have a 1978 Evinrude 115. I just restored the boat and took it to the water to actually run it for the first time. I finally got it to start after some issues with it dieing and backfiring. I got it started and idleing. I throttled it up and the rpm's came up just fine. I put it in gear and idled out. I started giving it throttle and i noticed it wasn't doing much. I got it to full throttle and it was not even close to plane. I throttled back and gave it gas using the throttle only and RPM's sounded good. I put it back in gear and the same thing happened. I have no idea what could cause a boat to do that. I am not sure if the backfiring and it being so hard to start is connected. Any advice would be great.
I have checked the compression, new plugs, new water pump impeller, carberator cleaned and gaskets changed.
