1978 evinrude 115ETL78C parts
gasrodjr
I am having problems finding parts for this specific outboard. None of the parts places seem to have this model number listed for parts. The closest i can find is a 115etz78c. Are the parts like carb kits, fuel pump, water pump, etc. compatible with my 115etl78c ? If not, can someone tell me where I can find these parts at.
Your location ?----What places are you looking for parts ??-----Those parts are common and readily available in my opinion !
gasrodjr
i am in houston texas. when i do the compatibility charts for parts on ebay nothing for the etz engine shows it is the same It always says not compatible with a 115ETL78C/
Johnson / Evinrude have different color paint !----I repeat it should be easy to run to your local dealer and they will likely have those every day parts in stock !
boobie
Use that closest # you could find in the Johnson section and you should be okay. I've only worked with outboards for the last 50 years so I feel good about it.
