fishing dad 2011
Thread starter- Joined
- Jun 21, 2011
- 46
Ok update on my 1978 starcraft w/ 70 hp evinrude..
Well I got a new steering cable and tilt tube and now I have steering. yay glad that part is over.
New issue arises when trying to run the motor, She fires right up if I put starting fluid in the cylinders but then it seems to flood right out when the gas hits. So I unhooked the gas line pulled out the soaked plugs cranked it over till all gas was out of cylinders hit them with starting fluid again and she fired right up and seems to run good untill the starting fluid is gone then she dies tried hooking up gas again and then same thing runs out the starting fluid then dies due to what appears to be over fueling. The rpms increased whith the cold start lever up and decreased when I put it down before it died.
I am such a noobie at this crap that I just thought I would ask on here to see if anyone has any ideas. This motor was winterized but has not been run in several years. Like I said it does fire right up no problem with starting fluid in the cylinders but it dont wanna run good clean fuel (mixed properly). the model number is 70873c its a 3 cylider 70 hp and a very clean motor except for the fule oil mixture that is now coming down the lower unit from what I assume is over fueling.
Thanks in advance for any help,
Fishingdad
Please please please can someone help???
Fishingdad
