1978 Evinrude 75 hp not starting
derrhalt
Maybe someone can help me. Bought motor last summer and owner said has not run in 2 years. Did compression check and got 115-120 in each cylinder. Installed new waterpump and impeller, new sparks and new lower gear oil. Battery is charged and working. What am I doing wrong! Any suggestions would be appreciated
Daviet
Re: 1978 Evinrude 75 hp not starting
Are you saying the engine will turn over but not fire off?
Have you checked the spark with an air gap tester?
Is the choke working properly?
derrhalt
Does not turn fast enough
boobie
Have your battery load tested and then check all your connections for being clean and tight.
derrhalt
checked all connections and battery and all seem fine. I put some fuel in the cylinders and put sparks back in and it turned alot faster but did not fire. Is there anything else I should check?
boobie
Check your spark. It should jump a 7/16" open air gap on a tester.
emdsapmgr
That engine must crank at least 250 rpm's in order for the ignition to fire the spark plugs. You can get some excellent ignition troubleshooting info for your exact engine at this website: cdielectronics.com
jeff cleaver
I just bought a Fisher King with the 1974 evinrude40, I cant get it to crank over with my switch, I get power to one side of the solenoid but when I turn the key one of the little wires gets power but that's it, I put a new solenoid on it, can anyone help me out on this issue?
Silvertip
Didn't read the rules about hijacking someone else's thread huh? No biggy, but by doing so you add confusion to this thread. Start your own thread.
