MadtownChris
Thread starter- Joined
- Sep 16, 2013
- 21
Hey folks,
First time boat owner (3mos or so) and have a 1978 Evinrude 85hp v4 on a 16' Yar-craft tri-hull.
Searching these forums has been super helpful so here I am hoping for some expert answers.
Boat was running pretty well for a while. Had some minor power loss / surge at WOT but infrequent.
Then last Saturday at slow speed dragged my new prop on I think mostly sandy bottom :grumpy:. The engine vibrated vigorously as you'd imagine. Immediately after that, it lost probably 50% of the power and RPMs. I could just barely get the boat on plane and at idle it would die.
Since we were near our destination, we docked for about an hour then got back in and headed back.
Symptoms on the way back were similar but now power loss was probably 75% though engine sounded smooth - the boat went no more than 5-7 mph at WOT - RPMs were similarly low. It took forever (hour?) to get back to the launch.
I checked the spark plugs with a tester and found that one cylinder had no spark. The problem seems to be the connector plug between the wire to the coil and the black power pack (?) thing. If I connect the wires outside the rubber boot, spark tester lights up so appears to be an easy fix. :joyous:
So here are a couple questions:
1. Does it seem like hitting the sand vibrated the bad connection completely loose which is the explanation?
2. Why would I have middling power for a bit, then almost none later? I would think losing one cylinder would result in a consistent speed. Maybe the cylinder was firing a little then not at all?
3. Is 5-7 mph at WOT something you'd expect missing just one cylinder?
4. Should I do anything to the cylinder with no spark before trying to run it? Like replace / clean the spark plug? Are there other effects on the engine from running without a cylinder for an hour I should address?
Thanks!
- Chris
Thanks!
- Chris
