Wildman4x4
Thread starter- Joined
- Sep 24, 2014
- 22
Hello all,
I have been over in the Boat Restoration, Building, and Hull Repair since I got this boat. I only paid $400 for it and the trailer so I am not out any real money.
So I have figured out so far that my floors are rotten and need to be replaced.
The engine is questionable at best. I have found the engine is missing it's distributor.
And has popped at least one freeze plug
Plus for some reason the oil filter has been blown off
So I don't know at this point if the engine can be rebuilt or not. I also am not sure if I want to try rebuilding it. I was told that I might be able to bolt a Chevy engine to the outdrive because it has a universal bellhousing. Can anyone verify or disprove this information? Also does anyone know what the maximum HP rating for one of these outdrives? Now all this is assuming that my outdrive is in good shape and can be used. If not then I will end up swapping in a new style outdrive. What would be the easiest outdrive to swap in to replace my stock unit?
