1978 Johnson 115 tilt/ trim problems
matt lewis
I have a 1978 johnson 115 on a skeeter that has tilt/ trim problems and I can't figure out what's wrong. the pump works but
and the trim rods will come out but the piston shaft wo't move in either direction. Also, the trim rods ,after a couple of in and outs will build pressure. When you stop the pump the trim rod will push out from the pressure. Does anyone know how this works and what might be the issue?
