Putzaroni1
- Joined
- Oct 20, 2012
- 108
I purchased a very clean 1978 2 hp Johnson 2R78R that has nostalgic value to me because I remember my Dad replacing our old Evinrude 60 with a 1978 Johnson 115. It was an awesome motor.
Anyhow, I just pulled it out from winter storage and put it in a bucket of water to give it a good run. I changed out the impeller and replaced the gear oil first. The impeller was end of life for sure and the old gear oil was ugly (marbled with dark and clearish). It's all clean and lubed up now.
My 2 questions are.
1) How can you tell if the motor is pumping water ? There is no telltale like on larger kickers. I see the 4 holes at the back that are exhaust. A little bit of water comes out of those but no where near enough to cool the motor. I ran the motor for 10 mins at 3/4 throttle and it didn't get too hot. I would just feel better if I knew how to tell.
2) The motor probably needs a really good run but I ran it at about 1/2 throttle to 3/4's with a couple bursts to full but it sputtered a fair bit and didn't run anywhere near as smooth as it did when I saw it run before I bought it.
I drained the fuel out of it before storing it but didn't fog it (will next time for sure). I also sprayed Carb cleaner at the carb while it was running and it would almost die and then rev back up. Does that mean there is an air leak ?
Does it sound like the carb just needs to be pulled off and cleaned properly ? I ordered the service manual off of EBay but it won't be here for a week and I'm getting impatient as this is going to be my personal fishing craft and fly fishing season is here.
Any suggestions or answers would be much appreciated.......
My 2 questions are.
