BonairII
Thread starter- Joined
- Jun 7, 2011
- 2,727
Found a 1978 Johnson 70hp w/ controls on CL today. Came with a new prop and brand spanking new fuel pump. 1/2 of the skeg is missing, but that's not a huge deal. Seller says he started motor in the spring and was getting water in bottom cylinder, so he pulled the motor off his boat. He just wanted motor out of his garage. I paid $100 for all of it, so it's a great deal IMO.
I pulled the plugs and the bottom electrode does have some white crud on it(caused by water?). All spark plugs look brand new, so the white crud on the bottom plug is the only clue I have. Seller said it was a bad head gasket. He said he had same problem with another 70hp motor years ago and a new head gasket solved the problem.
Did a compression check and got 100-105 for all cylinders, so I'm doubting it's a bad head gasket with the compression numbers being so close to each other. I'm guessing it's a leak in the exhaust.
Here's a link to the exhaust housing etc. What parts/gaskets are prone to leaks on this motor?
http://www.marineengine.com/parts/j...turer=Evinrude§ion=Cylinder+And+Crankcase
