1978 Johnson 70hp "runaway motor"....now won't turn over(Solved!)
BonairII
Installed a new(used) PP on the motor today. Spark on all 3 cyls now. Hooked up fuel and test fired it. It immediately "ran away" and the motor SCREAMED! :eek::eek::eek: Probably hit 10K+ rpm
I pulled all 3 plugs in a matter of a couple seconds(did it so violently that I pulled 2 wires right from the coils themselves).
I went to turn motor over after the "runaway" and now I get nothing(starter isn't getting juice). The electric choke IS working, but nothing from the starter. I checked the fuse at the back of the motor and visually it looks good.
What could have gone wrong? :confused:
F_R
Re: 1978 Johnson 70hp "runaway motor"....now won't turn over
Throttle wide open??? I don't know if that one has a throttle/starter lockout or not.
BonairII
Yup, throttle was wide open(controls were screwed up somehow). I'm going to run the throttle manually until I get that sorted out.
My question was referring how the 'runaway' could have caused the starter not to get juice now.
BonairII
Problem solved!
The culprit was the neutral safety switch. In my panic to pull the plug wires(and avert a blown motor), I bumped into the gear lever. It was about 1/4" forward of neutral.
Now on to figuring out why my fuel is dribbling out the bottom carb. :mad: I just pulled the carbs an hour ago to clean the carbs and reset the floats. I found a small amount of trash in the seat, so I figured I had the problem solved....but of course, I couldn't be that lucky. :(
