superharmonix
Thread starter- Joined
- Sep 5, 2010
- 140
After not running for 8 months I ran some sea foam mixed in with the fuel and after the smoke cleared it runs great! However, after the first day of running fine with no leaks, I saw a rainbow pool in the water all around the boat. The primer bulb was stiff, and the motor was leaking fuel. On the port side of the motor there's a plastic piece that runs up and down with three black tubes coming off of it. The top hose goes to the top carburetor, the bottom hose comes in from the filter, and the middle hose is only about 2 inches long and doesn't plug into anything(I am thinking carb overflow hose???). That middle hose is the one leaking fuel.
Anyway, someone told me to tap the carb with a rubber mallet or screwdriver handle to loosen up a needle or float, that maybe the sea foam cleaned off some gunk and it got caught in the bowl? I am no carb expert so I came to the place where I know I will get the correct answer, right here.
