1978 jonhson 70 hp idle adjustment??
mtduckhunter
where is the idle adjustment on this motor? its running high RPM's in neutral.
Theoutdoorsman
Re: 1978 jonhson 70 hp idle adjustment??
I'd strongly suggest you purchase a service manual prior to making any adjustments. Turn the wrong screws and you'll be in the market for a new powerhead soon.
mtduckhunter
thanks with my luck the worst will happen!
Boblester40
The idle screw is the lower of the two screws located on the levers which drive the carb and ignition timing adavnce . The top screw is the throtlle stop screw, just make sure it is not a problem with the control links when in neutral the lever should sit against the lower idle screw , if it not it is most likely a problem with the levers somewhere .
Rgds
bob
jtexas
Toddo1
Jtexas......great pic! Alot of 70 owners should benefit from this!
