1978 merc 1150 not starting
CougarBait
Ok...so...i cut fuel line short of filter and put in the my portable tank from my run about. Gas is fresh and has proper oil ratio. Check compression on all 6 cylinders and it was 120-125. I could have swore i saw sparks when i started playing with it yesterday...however tonight, I have NO spark. Battery is fully charged. Motor is spinning and 12 volts is getting to the starter. My buddy (who has a little more know-how than i) and I started working backward from the spark plugs to the battery. So, no spark at plugs. Put screwdrive in cap and no spark there either. Worked back to the coil. No Voltage there. Worked back from coil and the wires stray. Some go into a plate on the front of the motor (four hooked to screws on each side). Is that a fuse box/plate ? If so, how in the world is it accessed ? Is there a fuse block/plate on this motor ? Thats where the trail went cold. Presumably 12 volt are getting to this plate but not through to the coil ? Any thoughts ?
