1978 Merc 200 20hp charging system
ShafferNY
I have an old Merc that I've converted into a tiller. In doing so I decided to keep the electric start and charging system.
I've got the electric start all working, but I've got a couple of questions about the charging system.
First, there are two wires that come off the stator/lighting coil and both go to the rectifer. Does it matter which wire goes on the left and which goes on the right?
I suspect that it doesn't make a beans worth of difference, but I thought I'd ask to be sure.
Second, can the wire coming off the rectifier be connected directly to the battery side of the solenoid to allow charging?
TIA
Barnacle_Bill
Re: 1978 Merc 200 20hp charging system
It doesn't matter which side goes where and yes you can connect the output to the battery cable.
ShafferNY
That's kind of what I thought. Thanks for confirming it for me.
