AugustMoose87
Thread starter- Joined
- Mar 21, 2010
- 36
So last summer, I was having trouble going into reverse, you can get some details HERE
Anyways, I've pulled the lower unit apart, and as WingedWheel suggested, it looks like my shift cam is bad. The rest of the lower unit looks like it has recently been worked on (at least since '78), but the shift cam has a pretty deep groove worn in it, and the shift shaft bushing looks fairly gummed up, so I'm thinking they tried to get in and replace that when they did the rest of it, but couldn't get to it and decided to not fix what wasn't broken.
So, short of the long, I need to replace my shift cam. It seems to me that once I get the correct tool (on its way), I should be able to remove the shift shaft, pull the old cam out through the center of the front gear, and then get to have fun with some extra long needle nose pliers trying to the the new one lined up right. Will I be able to do that, or am I going to have to remove the drive shaft and the front gear?
I went to a marina where one of the tech was going to help me out by removing the bushing, letting me have fun getting the new cam on, and then put the bushing back in for a few bucks. But when I got there, he was at lunch, and his boss basically told me I was an idiot, that there was no way I could replace the bushing without completely breaking down the lower unit (ie remove drive shaft, forward gear and bearing, plus the shift shaft assembly). He then told me he could sell me the two tools I'd need (shift shaft bushing tool and one for the top of the drive shaft) for $60, then made the implication i wasn't smart enough to handle it, so I should give him $120 (then up to $200 a few minutes later) plus parts to take care of it....
