1978 Mercruiser 120 Hp problem with water in oil ?
nearpar
I started working on my 78 Islander which has a Mercruiser 120hp I/O I tried to start the engine in my back yard but it turned very slow. I hooked a garden hose directly to the thermostat by pass for cooling. After cranking a few more time I removed all of the spark plugs and I noticed that the number 2 cylinder had filled up with water. ( why cranking was slow )
DO I have something cracked ??? or was I not supposed to hook up cooling water at the by pass ? And yes the crank case is also filling up too as the oil level has risen and is milk white. Any thoughts ??? Was I not supposed to have full water hose pressure on the engine ?
Thank you in advance
Don S
Re: 1978 Mercruiser 120 Hp problem with water in oil ?
If you have a crankcase full of milky oil, (it only turns milky by running) then you have a cracked block and are now in need of a new block or engine.
nearpar
Actually the water is going into the cylinder with the engine not running. Cracked Exhaust manifold ?
