MikDee
Banned
- Joined
- Jun 6, 2007
- 4,745
Re: 1978 Mercruiser 228 Tune Up Questions
What you see in the first picture is the u-joint bellows which looks fine as you said, to the right is the shift cable (and bellows), to the left is your main engine water feed from the outdrive water pump impeller, and at the bottom is what appears to be a rubber type cone (instead of another bellows) for the exhaust, meaning someone changed it from thru the prop exhaust, to make a bit more noise, But it's not a problem, and it's all in good shape, a good thing.
By the way, I never bothered with the cables, as they worked okay for me, for as long as I had the boat, so I wouldn't know anything about them.
Also, if you have a 4bbl carb, it is the 228hp motor, the 2bbl carb was a 198hp.
The choke is an automatic butterfly on the carb like a car, but it maybe electrically operated. It is a marine Quadrajet carb.
