1978 mercury 175 compression
fish4970
my readings are as follows #1-#6 <br />137, 140, 137, 137, 140, 137<br />as i understand, it is good if there is no <br />more than 15% lowest & highest cylinder<br />my question is what is the factory compression.<br />i have an oem manual but it says nothing<br />about compression.<br />ps motor supposedly has 6 hours on overhaul with weisco pistons<br />thanks in advance
G DANE
Re: 1978 mercury 175 compression
Hi fish4970<br /><br />You will definately be fine. New compression probably between 135 and 140 on most mercs of these vintages.
JB
Howdy, Fish.<br /><br />The reason manufacturers usually don't specify compression readings is that you can get different readings if:<br /><br />You use different guages.<br />You use different techniques.<br />The temp of the engine differs.<br />The time since decarbing differs.<br /><br />As long as all of these factors are the same for all cylinders, the differences from one cylinder to another will be consistent, and will indicate any sick cylinders.<br /><br />Most engines are fine as long as all cyl. are over 100 psi and span less than 10-15%.
fish4970
thank you very much<br />i just overhauld the carbs <br />set the timing to factory specs<br />just need to rebuild water pump & go fishing
fish4970
I HAVE A GOOD QUESTION<br />I CHECKED THE WATER PUMP BECAUSE OF NO TATLE TALE<br />WHEN I TOOK THE WATER PUMP APART, IMPELLER LOOKED OK TO ME (ALL VANES INTACT & SNUG AGAINST SLEEVE)<br />SO JUST FOR GRINS I HELD A GARDEN HOSE TO THE<br />PIPE THAT GOES UP THE SHAFT HOUSING TO THE POWER<br />HEAD, THE RESULTS WER LOTS OF WATER RUNING OUT OF <br />THE DRIVE SHAFT TUBE, SOME WATER OUT OF THE EXHAUST TUBE , AND A LITTLE WATER OUT OF THE <br />TATLE TALE <br />IS THIS NORMAL<br />I WOULDEN'T THINK THERE SHOULD BE WATER IN THE DRIVE SHAFT PASSAGE<br />THANKS IN ADVANCE :confused: fishertodd1@msn.com
jim dozier
Tilt the engine up and do what you did with a flashlight shinning up the driveshaft housing and verify where the water is coming from. Are you sure it wasn't coming from the exhaust housing?
fish4970
i am pretty shure that it was coming from the drive shaft passage there is a partission between it & the exhaust itlooks like it goes all the way up
jim dozier
If you're correct, I don't think water should be spraying in the driveshaft housing. I don't know your engine but I would suspect the seal/grommet at the top of the water tube or the powerhead seal is leaking.
fish4970
it is a 1978 mercury 175 black max
fish4970
would the water pressure relief valve affect the<br />amount of water from the pee hole
fish4970
would like to hear what jb thinks
JB
Thanks for the confidence, Fish, but this is one I don't know much about.<br /><br />12Footer knows Mercs pretty well. I wonder what he thinks.
fish4970
how about it 12footer do you have any insite on this subject
