1978 Mercury 50HP Outboard engine
gtwillis
I have a 1978 Mercury 50 HP that has been in storage, after being winterized.
It has been in storage for a number of years. Do motors "dry" out?
Is it worth anything? welcome ideas...it has low hours
Laddies
Banned
Re: 1978 Mercury 50HP Outboard engine
I would do a complete lubrication and prelube the cyls and ir should start if the winterization was done properly they are great engines
gtwillis
I was able to get the engine to turn over, it had been in storage. It was winterized properly. It turns over but doesn't seem to fire. Any ideas? where should I start?
gtwillis
I filed the plugs and sprayed the carbs with carb cleaner and it started.
How does one lube the cylinders?
Thanks
RaScLeS
just use premix in the carbs next time. make sure it has fresh fuel and a good battery. new plugs are also a must
