1978 Mercury 70hp Adding Power Tilt Trim
Berdink
Google Ai tells me the 1978 Mercury 70hp didn't have a Power Trim option. But I'm reading that it came on later models.
Does anyone know if there are newer models that have Power Tilt Trim that can be modified to work with a 1978? I know I can buy a CMC, but I was wondering if there are power tilt trim from newer models that can work.
Honorary Supreme Mariner
Once again AI may be wrong.----Pretty sure power trim was an option in 78
Berdink
Okay, so Ai is an idiot!
Are there later models that I can harvest power trim tilt?
Berdink
I'm reading that finding a balanced fixed setting is good enough.
This will be a fishing boat.
No water sports.
Chris1956
I think you need a PTT unit from the 3 cylinder Mercs starting in the early 70s. I think you can also use one from the 4 cylinder 50HP Merc of the same vintage. I do not think the PTT unit from the 4cyl 800 or 850 or any IL6 will fit. The PTT system consists of 2 PTT brackets, PTT pump/reservoir, 2 PTT cylinders and 4 hydraulic.
One or more of the members on this forum have such a system on their motors and have provided pictures in the past. Hopefully that will do so again.
There are also aftermarket systems like CMC.
Nordin
Check out the 3-cylinder 50 and 60Hp from mid 80.es.
I think from 1985 (red-black-brown decals on the hood) and up, PTT from those might fit.
The 3 cylinder 65 HP beginning in 1972 had the trim / tilt unit that will fit the 70 HP models.
redneck joe
i have an 82 50hp and the two rams are on the sides so i would think it would fit but not sure.
I am sure that the cost of finding an operable used one is about the same as a new CMC off amazon....
