terry kozmo
Thread starter- Joined
- Jul 12, 2016
- 35
Yes, update, It runs, I had to take all three carbs off and clean, replaced floats, float needles, and reasm, started hard at first. but after idle adjustments on the land, it started easy and ran good, water test next, When I think back of all the things I did to fix this problem, I realized that as old as this motor was, this is all needed to have a good running motor. It is a tricky motor to figure out, and I learned a lot, all things must work together to make it run excellent, I figure for all this work (done myself), I saved over $1000 mechanics bill. and not to mention, I saved the boating season this year. It all started with a bad coil. Recap of all I did since owning this boat I love. new alum gas tank, fuel lines, plug wires, coil, carb rebuilds, water pump impeller, rebuilt fuel pump, spark plus, adjusted timing, and now the final water test adjustments..... wow, I think I can now understand this "Tower of power"... I think I'm now good to go...
