Gomer50
Thread starter- Joined
- Sep 5, 2009
- 507
I picked up a 1978 90hp inline 6 for next to nothing (0=$) and it looks good.There are however a few questions I would like to throw out here.With todays gas what should this one be set at for WOT degree wise.Also the switchbox looks to be damaged,is there a difference between 332-2986 inline 4 and 332-2986 inline 6 switchbox? And one other question this model calls for coil 332-4895T2 and I have one 4895A1 Ignition Coil 85 hp are these more or less the same (they look the same)?
Did a compression check all the way down 140 except number 3 which was reading
110. So I took the cover off on the starboard side for cylinder 3 and 4 and found a bunch of aluminum shavings,frozen rings,scored piston.I decided to take the whole motor apart to check things further.Number 3 piston wall was scored as well. So I honed it out (looks good),popped in a another piston and should be good to go.I do have one other concern the trigger (distributor) wires are shot so I would like to take one of my good 4 cylinder distributors apart and switch out the window disk.Is there anything special about these disks? I read on Cdi website that one side of the disk goes up,is there some special coating becuase the one I have is scratched up. This might be the dumbest question but never hurts to ask..
